How to get Environment variable value in Linux Labview.
dear team Ni,
We are having Licence version of Labview for Windows & Linux plateform.
I want to configure my application with Environemt variable value.
The way in which it is happend at Windows plateform is not happening at Linux plateform.
Prior to get these Env Variable value I have set the varaible with command,
export Var=A & the confirmed with command
echo $Var in Linux.
then inLabview programming , I am not able to get sutiable .vi to get Environemt variable value.
Suggest the solution to run the application at Linux with these Env.Variable value.
Jitendra kumar
(3,166 Views)
Hi Jitendra
So that I can understand more clearly what you're trying to acheive, could you supply your Windows code?
I'll have a look to see if something similar is possible on a Linux system.
Have you tried using the 'System Exec.vi' available in LabVIEW to interface the terminal directly?
Kind Regards
Chris | Applications Engineer NIUK
(3,089 Views)
