How to get Digital output port status?
      How can I get the status of a specific DO port? I am using PCI-6514. I want to give one or some lines new state without change other lines's state. If I can get current DO port's status(number or boolean array...), then I can only need to change one or some element of array, and write this new array to DO port.
    I have used some DO card from other supplier. There is a VI(or DLL) behaves as i have described. But I can't find it in DAQmx and property node.
     Is it exist?
(5,101 Views)
Hi Golden_H
I think there is no such property in daqmx. But what you could do is make a task per line, in that way you could address them all seperately.
Ton
My LabVIEW Ideas
(5,100 Views)
hi there
you can READ values from OUTPUT tasks. see attachment.
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(5,097 Views)
    Thanks at first!
    Now I know I have asked a so foolish problem.Smiley Very Happy
    I have tried this in PXI-6220 & 6070E.This method can work well. These cards's DIO ports can be set to DI or DO. So when I use creat channel.vi( select Digital Output),I can choose all digital channels.
 But When I use 6514,its DIO port can't be set(port0~3 is for DI, port 4-7 is for DO,only). When I create a DO task, I can only choose port 4-7. Now I have no 6514 card in my hand, so I can't try it. If it can work well with 6514 too, that will be  great!
(5,079 Views)
oh, you can try!
go to MAX and create a simulated DAQmx device! in almost most cases the simulated devices behave like a real one.
btw.: i wrote the vi i attached with a simulated 6514 and read the value of a DO port!:-)
Best regards
chris
(5,069 Views)
I tried this using a simulated device (PCI 6514) in NI-DAQmx v8.6.1f0 and it DID NOT read with your attached VI.
I tried this using a physical device (PCI 6514) in NI-DAQmx v8.6.1f0 and it DID read with your attached VI.
Is this a bug in DAQmx or should this be expected behavior?
CLA, CTA
(4,827 Views)
