How to generate variable delay to turn on/off the led?
Hello Everyone
I need your help in doing a simple project.
I have to turn-on and off a led connected to NI USB-6501 (turning on and off led using this is done), but with variable time duration, and description is as follow.
* Led turned on for 10 seconds
* Led turned off for 50 milli-seconds
* Led turned off for 60 milli-seconds
* Led turned off for 70 milli-seconds
* Led turned off for 500 milli-seconds
* Go back to step-1
Basically Led will remain On for 10 seconds and will remain off for 50ms + step_count * iteration.
I am new to LabVIEW and really don't understand how to do this.
Right now I am able to turn on/off using fixed delay and the block diagram is as follow.
I didn't have any clue how to implement this step counting and changing the off delay time with iterations.
I am also attaching the VI file.
Thanks in Advance
(3,343 Views)
Accepted by topic author xpress_embedo
So your off time, you need to start with 50 milliseconds and add 10 milliseconds each time.
Put that integer into a shift register.  Wire it through the False case.  In the true case, add 10 milliseconds before you put it back in the shift register.
(You can also use a feedback node,  then it can be contained withing just the one case and you won't have to feed wires across the loop or through the other case.)
(3,325 Views)
Thanks for suggestion, finally I am able to do it.
The Block Diagram is as follow:
True CaseTrue CaseFalse CaseFalse Case
Thanks again, i appreciate if you have any other comments on this.
VI is also attached.
(3,286 Views)
