How to generate from FLEXRIO 5785 in different AO?
I am using FLEXRIO 5785 4 channels ( 2AI, 2AO). I am generating a signal from one channel only and getting RF output from AO0, but how can i get RF output from AO1?
What will be the configuration for that ??
(650 Views)
Have you looked at the LabVIEW FPGA shipping example for the 5785?  This should show you how this is done.
ALE Consultants
(595 Views)
Yes, as per the example there is an option of processing mode,but no solution from it.
I doubt if any changes in port selection to generate?
(580 Views)
