How to generate biphasic pulses and change parameters?
Hi I am a beginner. I need to know how to generate biphasic pulses. What are the functions i need to use(the logic involved in labview to generate)? I should be able to change the parameters like duration,interval during the course of the program.
(2,694 Views)
Greetings:
You can go to the Analysis/waveform/signal generation toolbox and find Pulse Pattern. You can set the duty cycle, frequency and phase with the standard controls.
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,694 Views)
