How to generate a squarewave(4 khz) an output it using NI cRIO-9014
Hi
Well its a rather simple problem but i am somehow stuck in it. I am using a NI cRIO-9014... on its chassis i have mounted the analog output module NI-9263 through which i want to output a custom signal (9 pulses of square wave(4Khz, 0V and 5V levels) and then an idle time of 8 ms...and this goes on repeating).
However watever i try i cudnt get the square wave. I am checking the output on an oscilloscope and i am not able to find any relation between wat parameters i have put in the Labview and wat is visible on the oscilloscope.
I have so far tried to get the squarewave only using 'create analog signal' vi and 'simulate signal' vi but with no success. I have attched a screenshot of the way I am trying to do it.
Any help in this case would be very very helpful.
Thanking You.
Yours Sincerely
Abhishek Srivastava
(6,770 Views)
Hi Abhishek,
you have to use low level functions to realize your task. Therefore, generate a square wave with the "Square Wave.vi" and manipulate the 1D Array you're generating.
See the following diagramm:
this would be one possible solution, i think.
regards,
Tobias
(6,753 Views)
hi Tobi
Thanks for the reply.I have tried your suggestion and its generating the square wave. But actually i need to output the signal using a hardware(NI cRIO-9014 chassis, NI9263 Anmalog Output module). So i am facing 2 problems:
1) How to convert this cluster into a dynamic signal(cluster to array and array to ddt was my solution but its not working)
2) I have a feeling that my prior attempts at outüuting this signal failed not exactly because of the generation part but because of the fact that u cannot simply connect the generated signal with the i/o port on the cRIO chassis coz maybe u have to go thru the FPGA route .Any ideas? You could see(in the diagrams i attache earlier) that i simply drag dropped the port 'AO0' from the project explorer to the vi and connected the signal. Is this where i am going wrong?
(6,747 Views)
you're right, there are some points what you should consider when you try to output your signal.
First, when you're on a cRIO you can use either the FPGA or the ScanEngine in the RT Controller to generate the signal.
I recommend you to have a look at the Analog Output examples which comes with the NI-RIO.
(6,731 Views)
