How to generate a 1 millisecond impulse in Labview
Hi
I need to generate a 1 millisecond impulse in labview. I tried using the Impulse pattern VI. The minimum number of samples that i can input is 1, which gives me a duration of 1,5 sec approx. Moreover I still don't understand the impulse generation(no frequency input needed?)
Please help me with the generation of very short duration impulses which I then need to transmit through a speaker for some experimentation.
Thanks in advance.
(3,722 Views)
Hi sakshi,
you can generate a millisecond pulse on your DAQ device when you output samples with a samplerate of 1kHz and set one sample to TRUE and all other to FALSE.
So you need to create a waveform specifying your signal and output it with the correct sample rate. That's all…
(Don't get the idea to try this with wait functions. It will not work reliable.)
(3,719 Views)
Thank you so much! 🙂
(3,563 Views)
