How to generate Curves in labVIEW
Hi all,
Can anyone plz tel me how to generate the following curves in LabVIEW.
1.) Haversine Curve
2.) Lorentz curve
3.) Gaussian Curve
4.) Exponential rise Curve
5.) Exponential decay curve
Note: The inputs required for this curves are Amplitude, Phase, Offset
,Frequency and No.Of Samples
(3,975 Views)
Did you try to look at the Signal processing tools ?
I saw a lot of possible to generate different signals.
(3,956 Views)
I don't think all these function have the same set of parameters (for example, what is the "Phase" of an "exponential decay curve"???. That only makes sense if the data is complex).
If the desired function is not available, simply generate a linear ramp over the desired x-range and calculate the function using primitives from the numeric and mathematics palette. Should be trivial. See how far you get. 😄
(3,949 Views)
There iam not able to find the haversine, lorentz waveform patterns
(3,937 Views)
Accepted by topic author gsbng
Did you read the second part of my post above?
(3,920 Views)
Homework?
(3,918 Views)
