How to generate CAM signal from LABVIEW
Hi
  If anybody have solution please provide me the same.
I have CRK signal on the PXI card,now i want to generate CAM signal from labview.
How to program it,is there any drivers required for programming this.
Thanks & Regards
Anitha
(2,719 Views)
WHich version of Labview r u using?
Built in functions would be already avalailable....
And also search for the examples
(2,711 Views)
Am using LV8.5
I coudn't find out any examples.Can you please provide the path.
Thanks & Regards
Anitha
(2,709 Views)
Nithu,
8.5 should be fine....
Could you be clear of what exactly your req is?
-Suneel
(2,696 Views)
My req was
customer provided CRK signal on the PXI card.
program Labview to generate CAM signal?
Anitha
(2,691 Views)
Hi Nithu,
What kind of signals are these?  What is a CRK and CAM signal?  What PXI card are you using?  The more detail you provide, the more helpful we can be.
Jeremy_B
(2,657 Views)
