How to freeze analog output ?
In my LabVIEW program, I need to freeze analog outputs (keep the last value) when appears for example an emergency stop.
In this program, sometimes  I use  "simples" values to write outputs and other times I use waveforms.
Is there an easy way to freeze outputs in both cases ?  (a better solution than modifying all the VIs using analog outputs  😉 )
Thaks for your help !
(2,388 Views)
Hi cpit,
when you need an emergancy behaviour in your output VIs you have to program it...
An easy way would be: IF emergency condition is met THEN don't output values.
So a simple case structure will do the trick...
(2,381 Views)
In your emercency condition call Control Task.vi with Action = "Abort"
"Should be" isn't "Is" -Jay
(2,376 Views)
