How to format/customize system time?
Hi everybody,
I am Giridhar working as an Engineer in I-Design. Presently I am working with one of the database application, in which data will be stored in 24X7.And it is doing good while logging. According to the industry's time the day starts with 7AM in the morning and ends at 7AM on the next day. But normally date changes 12 AM to 12 AM on the next day. In this regard if I want to change the date as per industry's time what should be done?
Thanks and Regards
Giridhar
(2,598 Views)
Are you setting the date, or are you letting the database set the date? If you're setting the date, then you just need to write the code yourself to check the time and set the date based on your rules.
(2,578 Views)
