I had a test sequence that was built with Test Executive 5.1.1 and Labview 5.1.1. The sequence test step vi used Test Shell to allow the user to edit and config the test. After upgrading the test step vi from Labview 5.1.1 to Labview6.0 by mass compiling all vi to Labview6.0, an error occurred while editing the test vi. The error is as following:"Sequence Editor Error: Config Test Vi Callback.vi: Could not config test vi. Make sure the path to the vi is valid." I am sure the vi path is valid, does anybody has any idea why the path was not seen? How can this bug be fixed? Any hints or suggestion would be helpful.
