How to fix error 7?
I'm using testand with labview vi's, and at certain line I get this error, what I want to know is if I can keep on with the sequence of the program without making any changes so I can keep running the main sequence, and call to some kind of routine or vi wich tells me that an error ocurred during the running of the sequence
(2,929 Views)
Open LabVIEW >> help >> explain error will launch a window that you can put in the error code and it will return words to explain it. Error 7 is file not found. You can pull the error code out of the error strucuture to control a case structure for conditional logic.
(2,929 Views)
