How to fix date to correct form
I am getting the date from a CSV file which outputs the date in DD/MM/YYYY so it would be for example 06/05/2017 which is not the default that windows uses because windows shows a date format of 6/5/2017. I fixed this issue in Labview by having it search for the '0' and replace it with nothing using Search and Replace. I have two of these Search and Replace to get the 1st two zeros but not the last one. Now I am having the issue that the second '0' sometimes deletes the '0' in 2017 when the date becomes 06/15/2017. How can I make use of Search and Replace to just search for characters 3-5 or to make it stop before deleting the '0' in 2017.
I cannot change the date format from the CSV file because my program gets that data from a GUI and wish not to change the CSV.
(2,972 Views)
Accepted by topic author sportsguy99
Hi guy99,
use ScanFromString with format "%d/%d/%d", then wire the 3 resulting integers to FormatIntoString using the very same format string!
This will remove leading zeros…
What's wrong with dates shown including those leading zeros?
(2,964 Views)
Here is the part of the code I am taking about. A little confused on what your saying. As you can see, I had in a array and concatenate string for single string. Then it has the 06/15/2017 and i delete one string and the second one deletes the other '0' but in 2017. Dont mind the deletion of the " as I need that for a different reason. Why would I implement your solution into my code. I am a little confused. I want it to somehow not look into the 2017 ever.
(2,959 Views)
