How to fit to size to show the whole image in image display?
HI, I am using a control palette to display my video images using image display. However, the size is alway out of proportion. How do i show the whole image in the small box screen size. Basically how to fit to size for the images?
(4,043 Views)
This should do the trick:
Norbert
Norbert
Expert: Geometry
(4,039 Views)
Accepted by topic author fpaiy
You have that option in the Image Indicator itself. Right click the indicator you will get an option something like "Fit Image with Indicator" (Sorry I forgot the Actual name )
(4,037 Views)
The name is "Zoom to fit". Thanks.
(4,032 Views)
Ah.. Got it.. Thanks.. It was long before I was playing with those stuffs. 🙂
(4,029 Views)
Is there a trick for LV2010? A "Zoom to fit" function is nowhere to be found...
(3,922 Views)
