How to find the sum of the even numbers of an integer
I want to write a program that gets a user-input integer, and adds up the even numbers between 0 and that integer. So if 8 is inputed, the program returns 20 (=2+4+6+8). If 7, the program returns 12=(2+4+6). I know i need to use a loop, but not sure how to make it use the even numbers and find the sum
Message 1 of 10
(11,529 Views)
Write down in words on a piece of paper how you'd do it.
A tip for LabVIEW is to use the Quotient & Remainder function.  If you use that to divide a number by 2, it is even if the remainder is =0.
Another though,  divide by 2.  Take the quotient and add up all the values.  Then multiply that by 2.
Message 2 of 10
(11,522 Views)
Its Seems to be your homework, As suggested by ravens
Study about the behaviour of following Functions
R&Q (If R=0 Even)
For Loop(to Run for Given Integer times)
Conditional Indexing in for Loop (To index into array only if R=0)
Arrays(To Add Array Elements )
Message 3 of 10
(11,502 Views)
I would use Quotient & Remainder to get the number of loop iterations needed.  Then use a FOR loop with a shift register to keep the sum in.  So each iteration you add (i+1)*2.
Message 4 of 10
(11,454 Views)
@just Implementation is mine (Idea belongs to you @ Crossrulz)
Message 5 of 10
(11,441 Views)
Another way to do this.
Ben64
Message 6 of 10
(11,432 Views)
Guys, this is an obvious homework.  Do not do the work for them!  They will never learn otherwise.
Message 7 of 10
(11,427 Views)
No loop needed, just do the math!
(Hint: Search for the little Gauß)
Greetings from Germany
Henrik
LV since v3.1
Message 8 of 10
(11,423 Views)
Hi Pala,
two more simple options:
Message 9 of 10
(11,417 Views)
Solve for the formula, then use an Expression Node.
Message 10 of 10
(11,229 Views)
