How to find lowest 5% value from 1D array?
Hi Guys,
I have a set 1D of array with array size of 60.
I sorted them and now need to know the top and bottom 5% value.
Suppose, the 1D array:
0.0006
0.0056
0.5
0.57
0.73
1.67
3.56
10.45
11.32
13.45
I need to divide this array into 3 sections: mean value, top 5% and bottom 5% value.
Can anyone gude me to do it?
Message 1 of 9
(1,684 Views)
You posted a simple mathematical questions in a LabVIEW forum. Do you know the math and have trouble implementing it in LabVIEW? Do you have problem with the math itself?
If you have 60 points, each point is ~1.67% of all points.  So how many points would be 5%?
The mean value is a scalar, not a "section". Can you explain the terminology and what you mean by "divide the array"? Obviously this is not a mathematical division, but a splitting.
Message 2 of 9
(1,643 Views)
Hi, as altenbach mentioned, it is just a mathematical problem, but here is an example of how it could be done in case you still have doubts.
I would like to comment that depending on whether you are looking for exactly 5% or rounding, you should use an "absolute value" or not.
Best regards, a beginner in LabVIEW (2018, 2020, 2021)
jcosta
A beginner in LabVIEW using LV2018/2020/2021
Message 3 of 9
(1,578 Views)
Hi jcosta,
You know your two FOR loops do just the same as an ordinary ArraySubset function?
And you could also replace the whole ReverseArray+FOR+ReverseArray by a simple DeleteFromArray function?
Message 4 of 9
(1,575 Views)
Hi, that was my mistake, it really is much simpler and more efficient that way. Thank you very much for the correction and teaching.
Best regards.
jcosta
Message 5 of 9
(1,567 Views)
The compiler probably is smart enough to do this optimization for you, but instead of multiplying with 5 and dividing with 100 you can just multiply with 0.05.
Qestit Systems
Certified-LabVIEW-Developer
Message 6 of 9
(1,552 Views)
Again, the title and initial information does not give a clear enough message as to what the OP is actually requesting.  I looked at the data as all values that are within 5% of the Min-Max values.
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
Message 7 of 9
(1,516 Views)
I would use the built in percentile .vi
you can even look at the .vis blockdiagram and it is completly written in G...
Message 8 of 9
(1,505 Views)
20 to 80 5 to 95
attached as labview 2020
Message 9 of 9
(1,448 Views)
