How to find if a value of a graph has stabilized.
@RTSLVU I have a question specifically for you about the block diagram that you posted here, but I will not ask because I don’t want to change the subject.
Message 11 of 17
(840 Views)
@Gregory wrote:
Also, here is a simple way to abuse a queue to do it for you.
This is not an "abuse of a Queue" -- rather it is the "creation of a Ring Buffer", a structure that "saves the last N samples you feed to it", perfectly suited to "hold the last 15 minutes of data".
Message 12 of 17
(826 Views)
As I quick comment to that, it seems not scalable and would need to rewritten from scratch whenever the number of signals change and if we have an array of 100 temperatures, things become unmanageable. Then there is all that duplicate code!
Message 13 of 17
(822 Views)
Thanks Mr. Altenbach! You already knew what I was going to ask  😄
Message 14 of 17
(813 Views)
Yeah I know it's not very scalable. I wrote this over a decade ago for a power transformer qualification test and the transformers always had the same number of embedded thermocouples.
I never got around to making it scalable because I never really needed it again. But I would guess as long as your temperature measurements are coming in a 1D array and you are good with array manipulation you could use a 2D array to store all the measurements and reduce the redundant code.
=== Engineer Ambiguously ===
Message 15 of 17
(781 Views)
@RTSLV I bet it was when you first started to learn LabVIEW. I cannot imagine you coding like this. This looks more like my code  😂
Message 16 of 17
(771 Views)
Easy there. This is perfectly good code and might even be better in this particular case.
I think "rotate array" has some compiler optimizations where it actually does not move elements in memory so that might be lost if we rotate a 2D array in a FOR loop. Also the explicit version can be better parallelized. It is not always clear cut.
However, array "min&max" does not depend on order so rotating is not even needed if we just keep track of the insert point in a shift register instead. I would even get rid of the while loop and use a globally initialized shift register instead. The init case should have a control for history size. The mode should have a default value that is the most often used case, maybe it already is.
Message 17 of 17
(763 Views)
