11-28-2007 10:02 AM - edited 11-28-2007 10:05 AM
11-28-2007 10:09 AM
11-28-2007 11:33 AM
11-28-2007 11:58 AM
If the data is simple and you are guaranteed to have only two points that match, you can use "threshold array" of the array and of the reversed array, then do some math on the found indices. 🙂
See how far you get.
(Of course you could also fit the data to a real lineshape (e.g. gaussian) and get the width from the best fit parameters.)
11-28-2007 12:10 PM - edited 11-28-2007 12:10 PM
Here's one simple posibility. Use threshold array to find where it reaches 90, then continue with the inverted array and search for -90 for the second index.
11-28-2007 12:18 PM
Hi!
Actually it seems that my data has everytime two points that should match. Thou I am using labview 7.1 without fancy gaussian fits or so on.. 😞 My optional goal was to get full width at half maximum (FWHM) from my data (would be most welcome) But back to my problem I didnt get it how to use those threshold array functions to solve my case.. well I try to find out tomorrow when i'm back to office..
Thanks for the tips so far 🙂
11-28-2007 12:21 PM
07-22-2008 06:02 AM - edited 07-22-2008 06:08 AM
