How to extract specific rows from an array
Hello!
I’m trying to make a programme which, given a 2-dimension array, returns a 2- dimension array which contains only the rows having “1” as the first value.
 Schermata 2018-10-16 alle 18.09.13.pngSchermata 2018-10-16 alle 18.09.18.png
The problem is that I can’t tell the case structure to “do nothing” in case he encounters a “0”, so he gives me this output:
How can I write that in order not to have those “0; 0” lines on the A2?
Alternatively, could I write it so that it splits the A1 into two arrays: A2 (only made up of rows starting with “0” ) and A2 (only with rows starting with “1”)?
Thank you for your attention
Francesco
(3,871 Views)
Hi Francesco,
learn about all those different tunnel modes:
For that use case you need to learn about shift registers…
(3,865 Views)
Hi GerdW;
thank you for your reply.
I read about shift registers and tried to use them; I understood that they can be used to pass data between iterations but still I don't understand how to use them to do nothing during a single iteration.
(3,797 Views)
Just pass the values from the shift register straight through the case.  It is all about data flow.
(3,791 Views)
