How to extract a cluster controls array in 8.2 PDA Module
Hi Everyone,
I'm in the process of porting an application from LV 8.2 to LV 8.2 PDA. The application relies heavily on using the controls[] property node which I just found out is not supported in LV 8.2 PDA. Does anyone know of any alternative method of extracting a cluster's controls array without using a property node?
I've attached an example of the application.
Thanks for your help,
John.
(5,171 Views)
Hello Jon,
Currently, there is now way to obtain a reference to a control inside a cluster in LV PDA. I have experimented a great deal with alternatives, but to no avail. However, I think you you may be able to accomplish the same behavior using just an unbundle, or just using explicit controls outside of a cluster. Hopefully we will have that functionality in a future version of LabVIEW PDA.
Xaq
(5,148 Views)
Hi Xaq,
I've spent quite a lot of time trying to find an alternative without any luck. Without full property node support, there is no other option other than manual cluster interactions.
John.
(5,145 Views)
