How to extract 1 Darray and put them into new array
Its a snippet !
Save and You can drag and drop on to the block diagram.
But as you mentioned, I am not checking for "0" input.
You Need to modify it.
Bijay
Message 11 of 28
(1,768 Views)
I dont think so that my VI is giving unexpected zeros.
Can you please Explain? .
Are you using my code or created a new VI?
Message 12 of 28
(1,762 Views)
Hello ManLD,
I have attached back the vi that i can run. from your code , there are two block with question mark as shown in figure and so i deleted them and when i run it gives me zero for those which can't be devided by 30 . please advise .
thanks
regards
Message 13 of 28
(1,754 Views)
Ok.
The problem was that you don't have the OpenG tool that i was mensioned in my last post.
Download the code given below.
It will surely work for you.( I think)
Message 14 of 28
(1,741 Views)
Hello Pyae,
Your requirement is not clear.
Try modifying ManLD's given code.
ManLD : Post code with only LV as not everybody has OpenG VIs.
Bijay
CLD
Message 15 of 28
(1,733 Views)
Bijay,
I have modified the code without using OpenG in the last Post.
Regards
Message 16 of 28
(1,724 Views)
Hello MLD ,
the error still giving for delete element vi as attached . now i m downloading openG and will try again.
as i am new to labview , please advise .
thanks
regards
Message 17 of 28
(1,718 Views)
Hi
If you mention your requirement clearly probably someone can help you better.
Please explain what you want to acheive?
Message 18 of 28
(1,705 Views)
hi ,
sry that i didn't mentioned clearly. What i want is .. i have one array and i will to extract index of multiple of 30 from that array and put them into new array.Please refer my photo below and please advise me how shall i build it. thanks
Message 19 of 28
(1,691 Views)
That's why i asked you whats your requirement. Smiley Very Happy
Nevermind, i hope this solves the problem.
Bijay
CLD
Message 20 of 28
(1,685 Views)
