How to ensure "show context help" window is displayed on startup
Hello All,
I'm in process of preparing an application installer to be built, and am wondering if there's a way to ensure the context help window is presented to the user by default when they start up the application? I couldnt find any properties, methods or setup configurations that allow this to happen.
Thank You
-Ted
(2,714 Views)
The context help window is an item of the Development Environment.
What you could do is an mouse enter, and mouse leave event registring for all controls (VI->controls[]) and use the tip-strip/description to output to a window.
Ton
My LabVIEW Ideas
(2,710 Views)
With LabVIEW 8.2, I was able to display the Context Help window by using the Control Help Window function from the Dialog & User Interface > Help subpalette.  When I built this VI into an EXE, it still worked fine.
-D
(2,697 Views)
