How to enable function generator through TRIG input on the NI virtualbench?
Could someone please tell me if there is a function in LabVIEW available that would enable a signal to be generated by the function generator whenever a high input is detected at the TRIG terminal of the NI virtualbench. Also, how can I read-in or output a trigger signal from the TRIG terminal on the virtualbench using LabVIEW functions?
Thanks for your help,
Rowan
(3,216 Views)
You should really post your question to the VirtualBench board - https://forums.ni.com/t5/VirtualBench/bd-p/340
(3,206 Views)
Hi rgriffin,
Have you had a look at some of the tutorial available "How to Automate VirtualBench in LabVIEW" and "VirtualBench: Generate Standard or Arbitrary Waveforms With the FGEN". You can take a look at which instrument you are using and see if this helps.
Kind regards,
GajanS
(3,143 Views)
