How to embed web browser?
Hi - I would like to embed a web browser in a LabView VI. Specifically, what I am trying to do is to plot GPS coordinates to Google Maps. What this would involve is taking in the coordinates from the serial port, then calling some javascript functions in a web browser to plot them. Javascript functions can be called by passing them to the address bar. For example, you can type this into your address bar and hit enter:
javascript:alert("hello world");
So really - all I need is an embedded web browser (that shows up in my VI, not in a seperate window) that I can change the URL of. Can anybody suggest how to do this? I only need Windows XP compatibility, and I am using Labview 8.2.
Thanks!
-Mike
(8,021 Views)
Mike -
You can do this with an ActiveX container(in the controls palette) and either the Internet Explorer or Firefox ActiveX control.  I assume the properties exported from either of these controls will allow you to send your JavaScript command as the URL, but have never tried it so I don't know for sure.
J
Jason King
LabVIEW R&D
(8,014 Views)
(8,000 Views)
Hi - I tried to use the above example as a model for how to do this, but I'm having, well, odd results. Please see the attached block diagram so that you can see what I'm doing. Also - ignore all the serial code - it is related eventually (once I get this web interface working) - but right now it is irrevelant. All I'm trying to do is set it up so that I can click on the boolean button and have it go to the address in the URL control. But like I said - the behavior I'm seeing is very, very odd. Specifically - it seems the browser window often captures keystrokes, even when the url control has focus. For example, here is an example of oddness:
Start VI. It is at www.google.com. URL control says "www.google.com". I can put the cursor in the URL control and hit backspace, but it has no effect. I can highlight the whole thing and hit backspace and it will delete it. Now let's say I leave it at www.google.com and hit the boolean button. Now if I try typing in the URL control - I can type there - but the same typing shows up in the search bar in the google page!! What is going on?! This behavior has me very confused.
I have attached the block diagram as well as the whole vi for anybody's inspection. I would really, really appreciate it if anybody could take a look at this and see if they have any ideas as to what I'm doing wrong.
Thanks!
-Mike
(7,945 Views)
