How to dynamically store some information in the VI itself
I need to store some data (could be numeric/string/boolean) within the VI itself during runtime. So that next time when I run the VI I can retrieve that data from the VI itself. Is there any technique for doing this..?
Message 1 of 8
(3,614 Views)
This is the solution.
Norbert
Norbert
Expert: Geometry
Message 2 of 8
(3,610 Views)
You can use tags to store data inside the VI, but if you want it accessible after you close the VI, you are going to have to save the VI (this can be done programmatically using the Virtual Instrument.Save method. Note that this will not work in an EXE, because it can't save the VI.
See here for more details - http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-04-13-2009/m-p/888538#M401396
___________________
Try to take over the world!
Message 3 of 8
(3,584 Views)
Is it really necessary to store the data within the VI itself?  Could you not store the data in a file, like a config file, and just retrieve it when you start the VI again?
- tbob
Inventor of the WORM Global
Message 4 of 8
(3,569 Views)
I need to save the info in the VI itself because i will not transfer the configuration files to another machine. Also I want it to work in exe too.
Message 5 of 8
(3,545 Views)
There's no way to make this work in an EXE. The only way to save information in a VI is to SAVE the VI, and the EXE can't do that. If you want this to work in an EXE, use configuration files, just like everyone else.
If you don't want to manage files, you can try writing the information to the Windows registry using the registry VIs, but this solution is Windows only. You may also run into access rights issues if you don't handle things properly.
___________________
Message 6 of 8
(3,522 Views)
And just to clarify - you can READ the tag in an EXE. You can WRITE the tag in an EXE. You just can't save its value for the next time.
___________________
Message 7 of 8
(3,519 Views)
Accepted by topic author Flamboyant
Why can't you transfer the configuration files to another machine? If you install the exe on another computer you can also install the config files. An installer can also copy configuration files.
Message 8 of 8
(3,511 Views)
