How to dynamically rename and resize page label of Tab-Control.
Hi all,
I am trying to resize the page label of the Tab-Control using property nodes, but couldn't find any such property available for this.
Also when I try to dynamically change the Page label to some other text, LabVIEW throws following error.
"Error 1073 occurred at Property Node (arg 1) in Resize Page label of Tab Control.vi:
Possible reason(s):
LabVIEW: This property is writable only when the VI is in edit mode, or this method is available only when the VI is in edit mode.
Property Name: Page Label"
How can I dynamically rename and resize the page label of the Tab-Control?
Ajay.
Attachment:  VI which thrown error on renaming.
Ajay MV
(3,808 Views)
Its already discussed here
(3,806 Views)
Frabto,
    Thanks for the rename option.  I think that the setting the properties seperately caused that error as said here.  You have any idea about resizing the page labels of Tab-Control?
Ajay.
Ajay MV
(3,801 Views)
Including empty spaces with the Label will change the Page Label size.
(3,795 Views)
Including empty spaces either makes the tab selection go multiple-rows or adds page changing arrows as shown below.
Ajay
Ajay MV
(3,787 Views)
