How to draw line of best fit?
Hi Ruben
If you replace the "Write to Decimal String" with a "Write to Fractional String" this should give you the functionality you require.
You can set the number of decimal places by wiring a constant/control to the "Precision" input; the default is 6.
Does this solve your issue?
Peter D
Message 21 of 28
(1,114 Views)
Just need to change the string conversion to fractional string. See attached
Tim
GHSP
Message 22 of 28
(1,109 Views)
Thanks Peter,
Got it! You guys reply to the thread really fast that it solves my problem as and when I come across.
It has been extremely helpful.
Ruben
Message 23 of 28
(1,106 Views)
Thanks Tim
You prompt help since yesterday has brought me through a lot of my work and it was great with your immediate replies.
Really appreciate it and thanks a lot!
Ruben
Message 24 of 28
(1,104 Views)
No problem Just make sure you help someone else if you ge the chance.
Tim
GHSP
Message 25 of 28
(1,097 Views)
Yes I surely would help to the best of my ability.
Thanks again.
Ruben
Message 26 of 28
(1,079 Views)
The examples above are still a little convoluted. All you need is formatting the two fit parameters, e.g. as follows.
(Attached VI is in LV 8.0, snippet is in 10.0).
Note that if you use the correct format, the "+" is nicely replaced by "-" if the offset is negative. Modify as needed.
Message 27 of 28
(1,074 Views)
Thanks Altenbach,
Yes it solves the issue of the '-' and '+' signs in front of the 'C' value.
Thank a lot and appreciate your help!
Ruben
Message 28 of 28
(1,071 Views)
