How to download boot loader code to TI DSP using Labview
Hi all
I am using TI DSP TMS320C6414 processor for one of my applications
I am downloading bootloader code through FlashBurn manually.
I need to download the code to the DSP through labview
Kindly anyone say me how to download the code through Labview using Flashburn or any other method to download the code
Thanks and regards
Bala
(3,932 Views)
Hi Bala,
To deploy code onto DSP chips using LabVIEW, you will require the DSP Module.
The DSP toolkit is compatible with only some hardware.  Unless you are using one of the specific supported hardware there isn't a workaround to deploy code using LabVIEW.
(3,903 Views)
Hi Voodoo
Thanks for your reply
Part number listed does not contain the part number i am using, but it is of same series (6000series)
so is it possible to use NI-DSP toolkit for this.
With regards
Bala
(3,891 Views)
