How to do this better?
Hello!
We had this question before but noone answered so we make this VI a bit smaller... the problem is how we can do this in a better way? Any suggestions? The purpose is to use this together with a waveform chart. The problem is that we want to be able to set the measure-time before we start the measurement. So any tip or suggestion would be nice. Thank you and best regards.
(2,911 Views)
Hello Ex-jobb,
I just included another while loop with a "Start" button. Now you can set all values as you need and start the measurement afterwards.
Hope this helps,
(2,906 Views)
Hello GerdW!
Thank you for your help! We only need to read the buffersize, frequency for samples and measuretime once. That is why we did not have a while-loop from the beginning. Is there possible to solve this problem in another way? Do you have any tip? If one for example set measuretime 1.5 seconds we get 2 seconds because of the following chart could not handle float-numbers. But this is the solution that we have done so far... Then we get a delay in the system because of this problem...
Thank you again for your help! Best regards.
(2,900 Views)
