How to do state machine using events .
Accepted by topic author SaranVenkateshS
I'm attaching a small Event State Machine I built to illustrate User Events and using them as a State Machine.  Notice that, in this particular machine, no State takes a lot of time, which means that Events (either Front Panel or State Transitions) get handled quickly.  It does have a single loop, with Shift Registers allowing data to be passed between the "State Machine" and the "Event Structure" simply because they are the same wires in both.
Let us know if this is the kind of architechture you are seeking.
Message 11 of 23
(4,955 Views)
What does "I need a function which calls all the event function like state machine" mean? That is awful close gibberish. Likewise I also don't see the point of your code. You click a button in one loop that fires an event in a second loop, which fires an event in a third loop with very little delay between any of these operations.
Describe how you see it working. And please use simple words. As you can tell I am a simple man who gets confused easily.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 12 of 23
(4,937 Views)
Hi Mike ,
nice comment 🙂  gibberish
is there any way we can do state machine like State Chart .
http://www.ni.com/labview/statechart/
or else like this video
C# can do this job , why labview not able to do these kind of state machines
https://www.youtube.com/watch?v=GTogQTHR2d8&authuser=0
or else
UML based State machine
Message 13 of 23
(4,778 Views)
Hi Mike ,
Please let me know , if you still cant understand this gibbrish means 🙂
Message 14 of 23
(4,771 Views)
Didn't you just answer your own question there?  The State Chart module is an add on to LabVIEW.
GCentral
Message 15 of 23
(4,736 Views)
The state chart module is in essence an alternative editor. You can't just draw loops and expect them to operate as a state machine. Likewise, events are for signalling.
I have written applications where I have used events to alter the execution of a state machine that was running, but you don't need separate events for each state transition.
See here:
http://www.notatamelion.com/2015/02/23/building-a-proper-labview-state-machine-design-pattern-pt-1/
And here:
http://www.notatamelion.com/2015/03/02/building-a-proper-labview-state-machine-design-pattern-pt-2/
Also be very careful about trying to apply too much of what you learned in other languages to LabVIEW. Basic concepts are fine because a good idea is a good idea regardless of the language in which it is expressed. Specific techniques, however, often do not translate well.
Mike...
LabVIEW Champion
Message 16 of 23
(4,703 Views)
The links are now dead, I think the notatamelion website no longer exists. Is there any chance to see the information that was in those links?
Message 17 of 23
(1,168 Views)
I'm familiar with Mike Porter's site ("Not a Tame Lion"), which I visited when I was learning LabVIEW (and I think I met Mike at an NI Week in the 20-teens).  Mike was quite active on the Forums, but he hasn't visited since the summer of 2020, and might no longer be maintaining his site.
Message 18 of 23
(1,153 Views)
Enter the link in thee Way Back Machine
https://web.archive.org/
Message 19 of 23
(1,148 Views)
The SVN repository is still online
https://svn.notatamelion.com/blogProject/
Message 20 of 23
(1,136 Views)
