How to display the corresponding key number?
I need to make a display that can show which button I am pressing. Meaning there are 10 buttons and the display then has to show if it is button 1,2,3,4,5,6,7,8,9 or 10 I have pressed down
Any suggestions?
(3,274 Views)
Your best bet is to make an array of these buttons. Place an event structure on this array, such that everytime its value changes (by click of one of the buttons) you can read in the new value, and index the array to find which button has changed. Display that number.
Does this help?
Prashanth N
(3,270 Views)
(3,266 Views)
Accepted by topic author King123
That's great,
All you need to do now is:
1. Add an event on the event structure to point to "value change" of this array.
2. Compare old and new values to find which element has changed.
3. Increment index since it starts with 0.
I wrote a VI for you 🙂
Prashanth N
(3,256 Views)
That is so great. It is my first time using the program so have spend a lot of time on the same problem. I will try to analyze your solution 🙂
Thank you for your help
(3,253 Views)
At your service!
Prashanth N
(3,251 Views)
