How to display some html code in the front panel
Hello.
I am trying to properly display a few lines of html code in some kind of indicator on my front panel.
I was trying to use an ActiveX container with MS IE in it, but all the methods I find are to make it navigate to a given URL. I did not find any method or property by which I could give it some html code and it would display it.
Anybody know of a way to do this? It does not have to be using ActiveX or MS IE.
Thanks in advance,
Alejandro
(4,191 Views)
I think you will have to save it as a HTML file and give the address to that file to the ActiveX control, and I'm not sure if that will work, because a HTML file might need some header info, or something.
___________________
Try to take over the world!
(4,177 Views)
save the HTML as a file on the computer and point the control to that, it works quite well.
(4,173 Views)
Here is a simple way using the activeX that I have embedded in some programs in the past. You will have to call the file path to show the file.
Hope this helps some.
-Dave
(4,155 Views)
