How to display dynamic datas and double datas (chart)
Hi all !
I would like to display dynamic datas and double datas by using charts.
However, it doesn't work and I don't understand why.
Can you help me to fix that ?
- John
Message 1 of 9
(3,606 Views)
Hi John,
it "doesn't work" because you used DDT! Using simple datatypes it works as expected…
Message 2 of 9
(3,600 Views)
Hi !
Thanks for your reply !
Question :  What is the difference between dynamic datas and simple datatypes (in this case, double datas) ?
Actually, I have used Dynamic data type in order to simulate an signal.
In a few weeks, I will receive a sensor. I will use in LabView 'DAQ Assistant' whose the ouput is a Dynamic Data.
That's why, I used in first place, the 'Simulate signal'. So I think I should keep Dynamic Data Type
Is there another solution ?
Message 3 of 9
(3,571 Views)
I have tried something
We can see two plot but the sine plot is strange...
Message 4 of 9
(3,567 Views)
Hi John,
the sine looks like it should look with your VI!
You convert the DDT to a scalar DBL. That conversion will only use the first sample of the generated sine waveform - usually this is always the same (offset) value when you generate full periods… Or to put it in a mathematical expression: sin(0°)+4 = 4!
When you want to display waveform you should work with waveforms!
Well, I also simulated a signal in my example VI. I didn't use any ExpressVI to do so…
Nobody forces you to use the DAQAssistent ExpressVI. There are nice DAQmx functions available and LabVIEW comes with a lot of ready-to-use example VIs…
I do think you don't need to use the DDT. I think it's better to understand what is going on in your VI. And I think the DDT will be no help for you…
Message 5 of 9
(3,549 Views)
Hi  !
Sorry for taking so long to reply.
Anyway, Here I am now !
Actually, I have never used an sensor with Labview.  A friend told me I could use the DAQAssistent ExpressVI with Dynamics Data type.
So, I assume it was the only way.
If there is a simplier way, it will be great  !
Can you show me an example that simulate datas from sensor (so without DDT) and display it with double datas ?
Thank you for your help !
Message 6 of 9
(3,505 Views)
John.B,
While the DAQ Assistant can get you started quickly, it forces the use of DDT. DDT obscures the data it contains. There is no way to look at the DDT wire and figure out whether it contains one boolean or an array of waveforms or any of several other data types. The FromDDT node may let you coerce data into a meaningless form without warning you.  I do not know of any highly experienced LV programmer who uses DDT by choice.
The DAQ Assistant is just a wrapper around the lower level DAQmx VIs. You can opne the front panel of a DAQ Assistant (or most other Express VIs) and then look at the block diagrams. Even better is to use the Example Finder (under the Help menu). Search for examples related to the kinds of measurements you want to make. A few of the examples in older versions of LV were not too well written but most of the newer ones are quite good. When you find an exmaple which is close to what you want to do, make a copy of it in a different location with a new name and then modify the copy to meet your needs.
Some place on the NI web site is a document which shows how to use a small portion of the available DAQmx VIs and functions to do most of the common things.
Lynn
Message 7 of 9
(3,487 Views)
I belive you are referring to this paper: Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
Message 8 of 9
(3,478 Views)
Exactly. Thanks, crossrulz.
Lynn
Message 9 of 9
(3,475 Views)
