How to disable "Use Default If Unwired" by default?
When scanning part of my code, I noticed a wire output tunnel set to Use Default If Unwired, that would have really messed things up if I'd tried to run the program.  Is there a way to have that setting disabled by default?  I'd prefer to conciously enable it rather than have to remember to disable it whenever I wire across a structure boundary or add a new case.
I am using LabVIEW 8.5 so I'd need a solution for that version if possbile.  It would still be nice to know if anything was added in later versions, even if I can't use it myself yet!
Never say "Oops." Always say "Ah, interesting!"
(3,130 Views)
Accepted by topic author J.Mamakos
(3,115 Views)
Thanks for clearing that up.  I guess I'll have to just keep deselecting the option every time for now.  Smiley Sad
(3,105 Views)
