How to disable "Close on successful completion"?
Hey guys,
I just had a quick question about the deployment dialogue in LabVIEW
There is a check box called "Close on successful completion" when you deploy your LabVIEW code with shared variables or deploy the code to RealTime OS.
Is there a settings saved somewhere that I can uncheck this? I checked the xml file of labview project itself but cant seem to find it.
(3,823 Views)
When you Deploy the code are you not able to unckeck the option? Once you have done that then next time onwards your selection will be saved and remain unchecked.
(3,819 Views)
Sometimes the deployment occurs too fast and I cant uncheck it.
I just wanted to know if there was another way to uncheck it so that I can check the logs for any disturbing warnings
(3,814 Views)
I am not sure about other ways but one workaround is, diconnect the RT communication and deploy so it will fail. Now you can uncheck the option and then the selection will be retained.
(3,807 Views)
