How to determine if string represents a valid numeric
Using Labview (6.1), what is the easiest way to determine if a string represents a valid numeric?
(2,537 Views)
Try using the "Scan From String" function on the string palette. Using a format specifier of "%f" or "%d" will try to format the string into a number. If the string contains anything besides numbers, the function should generate an error.
Ed
Message Edited by Ed Dickens on 10-03-2005 03:03 PM
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,532 Views)
