How to detect variant type casting
I have done a piece of refactoring lately that involved replacing a variant with an object.  Variants being wonderful like they are, any old interface VI which would take a variant input simply casts the object input to a variant.  Is there any way of searching in LabVIEW for this casting action?  I'd prefer not to have to find every module that took the variant/now should take an object, if possible.
(3,395 Views)
Accepted by topic author reformedView
Easiest way is to open your project, open a VI that you know has the function, click on the function and hit <ctrl>+f.  The find dialog should already be set to "find objects" with the function already selected.  Set the dropdown to <All VIs in Application instance> and hit Find.
You can do it without selecting the function before <ctrl>+f -- you'll just need to a little bit of navigation.
(3,383 Views)
Hey, good one.  Silly me 😛  Thanks.
(3,380 Views)
You are trying to find when the data was just simply coerced into a variant?  Sorry, but there is not any simple way to do that.  You will need to go through each module and find that ones that you changed.
(3,378 Views)
