How to detect mouse movement/key press on Mac?
Need to write a VI that will detect/report mouse movement (ie. returns it's location) and any key (or key combinations) pressed. And, to send the mouse pointer to any location on screen. Using Labview 6i on Mac.
(3,137 Views)
LabVIEW 6.1 has an event structure that can monitor mouse movements and key presses. The following address has more info on 6.1: http://amp.ni.com/niwc/labview/lv.jsp?node=1381
I do not know how you would move the mouse programatically on a Mac.
(3,137 Views)
Was not able to find the event structure that you were referring to. Is it possible to post the function or VI's name? BTW, I'm using Labview 6i not 6.1. Thanks.
(3,137 Views)
The event structure is new to LabVIEW 6.1. I could post 6.1 code but I cannot save the structure for previous and LabVIEW will not open a VI from a newer version. The best place to learn about the event structure is on the What's new in LabVIEW 6.1 page.
(3,137 Views)
