How to detect a user action in the graph palette with an event node?
is it possible to detect an user action in XY-Graph "graph palette" with an event node?
Thanks a lot and best regards,
Michael
(4,714 Views)
Hi Michael,
you can detect mouseclicks in the graph palette with the event structure...
(4,700 Views)
Hello GerdW,
thanks a lot. I tried it, and it works for the "cursor button" and the "hand button", but not for the "zoom buttons", because here I need two clicks.
Do you have any idea how to detect the zoom buttons?
Thanks a lot and best regrads,
Michael
(4,685 Views)
Hi
in the event structure, you have an event for the XY graph corresponding to Range change or something (i dont have LV in english).
It will catch a zoom, which is basically changing the X and Y range of a graph
Giuliano Franchetto
Student at the l'Ecole Nationale Supérieure des Mines de Saint-Etienne, cycle ISMIN (FRANCE)
(4,676 Views)
thanks a lot. In German the event is called "Änderung des Skalierungsbereichs". The problem is, that you can only detect the zoom tool, when you click inside the grpah after you have selected a tool.
Only the selection itself does not result in an event.
Here ist my compelte problem:
I have a front panel with 6 xy-graphs and I want to use the functions of the graph palette. If I choose a tool of one graph palette, I will choose them for all other graphs too. So I need to detect a user action in the graph palette to set the other 5 graph palettes to the same tool.
Any ideas?
Thanks a lot.
Michael
(4,654 Views)
Accepted by topic author MichaGue_01
Hi Michael,
so you only need one tool palette for all 6 graphs? Make your own one using some (customized) buttons and you're fine...
(4,652 Views)
Hi GerdW,
thanks. The idea is so simple.
Michael
(4,646 Views)
