How to denormalize a normalized vector in LabVIEW
I use the Normalize node to normalize a list of numbers and then to do some mathematical processing.
Now I would like to convert back to the unnormalized numbers after the processing.
I could not find a node to do this automatically.
Any ideas?
Message 1 of 9
(3,298 Views)
Hi ziedhosni,
Can you provide the mathematical formula for that denormalize calculation of "unnormalized numbers"?
Message 2 of 9
(3,296 Views)
Just use the number you had before you used the Normalize node, you already have the values no need to "unnormalize".
Ben64
Message 3 of 9
(3,290 Views)
Any ideas?
are you using this:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvanls/normalize/
or that:
https://zone.ni.com/reference/en-XX/help/371361R-01/lvanls/scale/
Message 4 of 9
(3,263 Views)
I need the unormalized values after the mathematical processing.
The vector contains a subset of a range [-180,180] and a subset of [1.2,1.6].
I would like to add +x lets say +0.5 to the normalised full set ranging [-1,1].
Adding +0.5 to all original unnormalised values will not have the same effect as when I used the normalization.
Message 5 of 9
(3,261 Views)
Message 6 of 9
(3,260 Views)
Hi ziedhosni,
Can you provide an example VI containing your example data?
It is not clear (to me) how all those ranges fit together (-180…180, 1.2…1.6, -1…1)…
Message 7 of 9
(3,243 Views)
Here is an example snippet of what I would like to run.
Message 8 of 9
(3,212 Views)
Accepted by topic author ziedhosni
If you read the Help for the Normalize function, it tells you exactly what computation it performs to do the normalization, which involves computing the mean and standard deviation of the original data, then "normalizing" using these two quantities.  It does this by subtracting the mean and dividing by the standard deviation.
If you retain the original mean and s.d., you can easily reverse the process -- multiply your normalized values by the standard deviation and add back the original mean.
Please read the LabVIEW Help.
P.S. -- I hope you understand "what you are doing".  I'm suspicious of a data set that is described as -180 .. 180, as it sounds like "polar angles" for which "taking the mean" might not make sense!  There are ways to treat "direction data", but this is something of a specialized topic.
Message 9 of 9
(3,199 Views)
