How to define the frequency resolution after FFT transform?
Hellow! Anyone tell me how to define the frequency resolution in FFT transform? thanks!
(4,432 Views)
By how long your sample time is. If you sample 1 second of data, your frequency resolution will be 1 Hz, 100 ms -> 10 Hz.
Randall Pursley
(4,428 Views)
thank,but how to define the frequency range? for example,if my data has 10 seconds long,then what my maximum frequency?
(4,425 Views)
Your maximum frequency is half of your sampling rate.
Randall Pursley
(4,418 Views)
Remember the FFT contains both positive and negative frequencies, so if your sampling rate is 1000 Hz, the FFT frequency range is -500 Hz to 500 Hz
Randall Pursley
(4,416 Views)
Hello
Please, take a look at this tutorial about FFT:
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/c045a890751303a6862568650061ea98?OpenDocument
Probably it will help you .
Greetings
Alipio
"Qod natura non dat, Salmantica non praestat"
(4,421 Views)
The new NI Measurement Fundamentals series also cover this topic in a higher level tutorial:
Analog Sampling Basics
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(4,380 Views)
