Hi All,
I have done program which create a xml-file from typedef. My target is save and read parameters from xml-file. The problem is that when I add new elements to typedef all old parameter values are set to default values. I have quite many parameters and I need to add/remove parameters during the development. Is there a way copy old values to new ones if names are equal? In speudo code I need to following things:
1. Read parameter names and values from old file
2. Create new XML-file
3. Replace old parameters in xml-file with new ones if names match
#1 and #2 are easy to program but #3 is more complicate.
BR,
Jim
