How to create valid template for match pattern?
Hi
I would like to create a valid template for match pattern? I use Labview 2012. First I save a png file taken from my digital camera (Screenshot1). Then I use it for a template with IMAQ Setup Match Pattern 2 and IMAQ Match Pattern 3 (Screenshot2). When I try with Vision Assistant and this template the error is the same. When I create a new template using Vision Assistant and use it in my example everythink is OK.
Help me to resolve the problem?
I have attached the screenshots of my code where appears the error.
(3,024 Views)
Instead of screenshots, if you attached your code (meaning the VI or VIs themselves), we could try it, see the error, and try to fix it.
(2,980 Views)
