How to create thread dynamically ?
Hi everyone,
I m using LV 8.2 or 8.5 and NI-VISA 4.1.
Several serial ports are emulated on my PC with USB-Serial cables. Then boxes which will be under tested are connected to those serial ports.
The first thing which must be done is to send a command when they are switched on at the same time. Therefore, I use multi-thread application with reentrant VIs. But we don't know how many serial ports are emulated and we don't want to limit the number of serial ports.
Have you got any idea about how to dynamically create thread and get thread ID (one thread by serial port) ?
Many thanks for your answer and for your help.
Message 1 of 12
(6,113 Views)
Hi Zaboulou,
one way could be to create a vi template. This template can be start so often you need it.
Mike
Message Edited by MikeS81 on 02-12-2008 03:41 AM
Message 2 of 12
(6,106 Views)
Thanks for your answer.
But if I use a VI template, I guest I need a For loop to start each instance. No delay should be introduced.
In attached llb, maximum number of serial ports is 4. But I want any number limitation.
Message 3 of 12
(6,089 Views)
Hi Zaboulou,
i think you need a loop. But you can do it in this way:
  1. create all instance of the vi you need
  2. configure each of them with the right COM Port and what else
  3. each instance wait for a notifier
  4. start each process at same time by using a Notifier which was send from a central point
By using something like this you can create all process in a while or for loop and anyhow all start at the same time.
Mike
Message 4 of 12
(6,086 Views)
Hi Zaboulou
I'm writing because I want to do a similar program and I wondered if you found a solution to connect several devices to the serial ports.
I've been doing some proves using VI from templates but when they are called from the main, they are opened slowly and I don't want that.
I've tried to reduce the size of the templates and change the properties of the subVIs that are included in them but this things don't work.
I hope that you can share the solution if you found it or in other case give some suggestions in order to solve this problem.
Best regards, dtp.
Message 5 of 12
(5,947 Views)
You ll find my solution and I hope it helps.
Zaboulou
Message 6 of 12
(5,920 Views)
Could u pls post those VIs in 8.2 ? I couldn't open yours as I don't have the version 8.5.. thx
Message 7 of 12
(5,906 Views)
Hi m_min,
here it is for LV80.
Hope it helps.
Mike
Message 8 of 12
(5,903 Views)
Thank you. I'm going to check it out
regards, dtp
Message 9 of 12
(5,868 Views)
Hi Zaboulou,
I opened the VIs that you sent me but it seems that a VI is missing, its name is Enter SM.vi and appears in the vit.
Could you send it, please?
regards, dtp
Message 10 of 12
(5,852 Views)
