How to create some new loops to monitor parameters
Hello Everyone,
Now, I should create some new loops to monitor parameters, every parameter have own Monitoring frequency.
I try to use  For  to use sub VI, but the sub VI contain the infinite loop for monitoring and the For just run one time, that is I just monitor one values.
My main question is this: How to create some new loops to real-time monitor  different frequencys parameters
(2,809 Views)
Accepted by topic author Yawl
Without seeing your application as a whole, it's hard to give an exact answer, but there are basically two steps (and a lot of details):
  1. The data you wish to monitor has to be accessible or published in some way like being in a global, FGV, user-defined event, etc.
  2. Create a VI that has a While loop that reads that global, FGV, or whatever repeatedly. The rate at which you read it is a function of how fast the value can change.
That's about it -- except for all the details I mentioned before.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,767 Views)
If very data has a globel, the worload is big, and I can create a vi that monitor all data in this way.
Is there any solutions to create new loop or other way to monitor data that I want.
thanks.
(2,746 Views)
Please consider using the state machine architecture.
This will definitely help in your case.
HTML tutorial  HTML tutorial
162+ CLDs & 10 CLAs Trained
LabVIEW Training resources
(2,737 Views)
OK, thank you!
(2,728 Views)
