How to create radiobuttons???
Hi group,
I've a little problem by creating a Group of radiobuttons on a panel.
Just one button should be selected the others not. What is the Way to
get this running? I just tried to use an attribute node but i can't find
an entry for this problem.
Is anybody there who can help me??
Thnx
Henrik
(3,485 Views)
Henrik,
there is an example of this in the national instruments database - do a search
on radio button example labview from this website and it will lead you there.
pat
Henrik Skupin wrote:
>Hi group,>>I've a little problem by creating a Group of radiobuttons on
a panel.>Just one button should be selected the others not. What is the Way
to>get this running? I just tried to use an attribute node but i can't find>an
entry for this problem.>>Is anybody there who can help me??>>Thnx>Henrik>
(3,485 Views)
Radio buttons are not as big a deal as they seem to be at first glance, you
just need to map your logic as you go. I have not downloaded the NI solution
since it appears to be a huge solution to a small problem. I've implemented
radio buttons in dozens of different ways (up to a 16X16 switching matrix
where columns are radio but rows non-exclusive), and never had to rely on
a 20M file from NI to do it.
It is easiest to group your buttons either as an array (no independant labeling
on the buttons) or a cluster (each button can carry it's own label). One
approach would be to use a shift register to check status each time through
the loop (current aggregate = previous aggregate?) and if anything has changed
find the 'new' true, set all to false, and then reset the 'new' true back
to true. There are numerous ways to do it, not all relying on shift registers
(not all relying on front panel grouping). The one constant is that you
will have to rely on using locals (either current LV local or older LV2 style
globals, a subvi with a shift register).
Things to keep in mind are race conditions (this one can bite you if you're
not real careful; your buttons will reset themselves to the previous condition
rather than updating to the desired new condition) and whether or not it
is acceptable to have NO BUTON selected. If NO BUTTON is not acceptable,
then you need to also remember in your logic what the previous condition
was, and return to that if the user inadvertantly clicks on the currently
selected button (setting it to false while not setting anything else true).
Bottom line: speed a little time with the logic and it will become clear
(if/then/else sort of considerations).
hth
(3,485 Views)
The easiest radio button solution (imho) is a custom control that's included
with LabVIEW. Go to Examples\General\controls\booleans.llb and open any one
of the controls in there (i.e. 4 Radio Buttons.ctl). These controls are modified
slide controls and are very simple to use. There is no extra code required
for button management. If you need more than 5 buttons, you'll need to edit
the control but if I remember right, there was detailed instructions for
doing this in the info-labview archives.
"cka" wrote:
>>Henrik Skupin wrote:>>Hi group,>>I've a little problem
by creating a Group of radiobuttons on>a panel.>Just one button should be
selected the others not. What is the Way>to>get this running? I just tried
to use an attribute node but i can't find>an>entry for this problem.>>Is
anybody there who can help me??>>Thnx>Henrik>>>Radio buttons are not as big
a deal as they seem to be at first glance, you>just need to map your logic
as you go. I have not downloaded the NI solution>since it appears to be
a huge solution to a small problem. I've implemented>radio buttons in dozens
of different ways (up to a 16X16 switching matrix>where columns are radio
but rows non-exclusive), and never had to rely on>a 20M file from NI to do
it.>>It is easiest to group your buttons either as an array (no independant
labeling>on the buttons) or a cluster (each button can carry it's own label).
One>approach would be to use a shift register to check status each time
through>the loop (current aggregate = previous aggregate?) and if anything
has changed>find the 'new' true, set all to false, and then reset the 'new'
true back>to true. There are numerous ways to do it, not all relying on
shift registers>(not all relying on front panel grouping). The one constant
is that you>will have to rely on using locals (either current LV local or
older LV2 style>globals, a subvi with a shift register).>>Things to keep
in mind are race conditions (this one can bite you if you're>not real careful;
your buttons will reset themselves to the previous condition>rather than
updating to the desired new condition) and whether or not it>is acceptable
to have NO BUTON selected. If NO BUTTON is not acceptable,>then you need
to also remember in your logic what the previous condition>was, and return
to that if the user inadvertantly clicks on the currently>selected button
(setting it to false while not setting anything else true).>>Bottom line:
speed a little time with the logic and it will become clear>(if/then/else
sort of considerations).>>hth
(3,485 Views)
Hi Dennis,
thnx for this easy way to implement such buttons..i will remember these directories
Ciao
Henrik
(3,485 Views)
