How to create exe in Labview 5.0
Hi
I am using Labview 5.0 . I would like to create an .exe from using set of vis i have.Please let me know
a) procedure to create exe file using 5.0
b) additional components required if any and possible link to download them
thanks for your help
Gajanan
(2,950 Views)
Hi Gajanan
I recommend you this link:
http://www.ni.com/support/labview/toolkits/appbuild/
This will describe you exactly what you have to do.
Luca P.
Luca
(2,950 Views)
Thanks a lot Luca. That really helped me a lot.
However he is one more problem I am facing right now .
Using Labview 5.0 I have created exe for my application using mentioned procedure.
My application works fine when I execute my main Vi from Labiew , but when I execute it using the exe which I have created , it gives me following error
"Error : 10240 occured at DIO port Config
Possible Errors
NI-DAQ LV: The driver interface could not locate or open the driver"
can anybody help me out
Gajanan
(2,950 Views)
