How to create .apk file
Hi , I want to create an Mobile apk. Is it possible to create using labview?
Message 1 of 12
(4,037 Views)
No
=== Engineer Ambiguously ===
Message 2 of 12
(4,029 Views)
No.
Message 3 of 12
(4,022 Views)
BTW: If what you are wanting to do is run your LabVIEW program on an Android phone or tablet, forget it .
The closest you can get is to use the Data Dashboard for LabVIEW
Be advised the Data Dashboard is NOT LabVIEW running on an Android device
It is merely displaying indicators from LabVIEW program running on a computer.
Message 4 of 12
(4,014 Views)
Hi, GerdW i have found one way to create .apk file
Step 1). I have created web app using labview and system link cloud and it generated one url
Step 2). Using MIT App inventor in that i used web viewer tool and pasted that generated url and created apk
Message 5 of 12
(3,935 Views)
Hi, RTSLVU i have found one way to create .apk file
Message 6 of 12
(3,930 Views)
Hi Nivas,
no need to answer two times with the same text, we all can read the full thread…
Are you using LabVIEW ("classic") or LabVIEW NXG when you create a WebApp with SystemLink cloud?
Message 7 of 12
(3,925 Views)
Oh.. Ok  GerdW
I used LabVIEW ( classic) but I also know to create using LabVIEW NXG.
Message 8 of 12
(3,897 Views)
@shakir512 wrote:
Yes you can create
Lovely qualified answer. 😀
Yes you can create any APK file of course, by invoking the according tool through System Exec.
You also can create a Web App with the Web Development Toolkit and then create an Android package with it as explained earlier in the thread.
And the backend can be developed with LabVIEW as a WebService.
But you can not build an APK from your LabVIEW source code directly. LabVIEW has no compiler for Android and never will have one.
Rolf Kalbermatter  My Blog
Message 9 of 12
(3,087 Views)
I think joshuaperez and shakir512 are spammers, this is their only comment...
Message 10 of 12
(3,040 Views)
