How to create a working link anchor in an EXCEL document with the report generation toolkit?
I am using the latest report generation toolkit and want to add links on the first worksheet pointing to the other worksheets in the same document.
I am using the "Append Hypertext Link Anchor to Report" VI. The links are created, but don't work when clicking them.
Question now is: How does a link to a cell on a different worksheet needs to look like?
It can not be that complicated but all variations I tried did not work and I could not find any information about this problem. So any help is appreciated!
Thanks and Regards,
Ingo
(5,943 Views)
Accepted by topic author IngoB
You have to go down to NI_ReportGenerationToolkit.lvib:Excel_Insert_Link.vi On the Hyperlinks invoke node you will need to wire the subaddress node to the cell location you want to link to.
Brian
(5,939 Views)
Thanks, Brian, for your support! - It's working.
It's hard to understand why NI did not pass this parameter to the top of the call chain...
I also needed some time to understand the syntax of the string passed to the subaddress node:
The name of the worksheet needs to be framed by single quotation marks and the following cell address must preceeded by an exclamation point (!).
A working link pointing to cell "A1" of "Worksheet 1" looks like:
'Worksheet 1'!A1
Maybe also of interest: If you want to point the link to a worksheet inside the document itself, the parameter "address" (URL of link - href) can be left empty.
Thanks and Regards,
Ingo
(5,903 Views)
